Brabus Sport Illuminated shift lever
meb
cls 320
Anyone had any experience installing one of these? Car is a CLS 320 '05
It is a Brabus shift lever with an LED on the top that lights up :cool:
It has 2 bare, tinned wires (red and black) coming from it which I assume are to be spliced into the illumination circuit. Problem is no-one around here (Bath Bristol area) has seen one before and I am being quoted 4 hours by MB Bath and an independent which I think is way OTT...
Anyone had one fitted before and anyone know where I can go to get this done?
roadhog
Sunny Norfolk
W124 300D x2, C124 300
You've already figured out how it works, why not give it a go yourself? :)
M
meb
cls 320
I don't know how to remove the shift lever, don't know where to find the illumination circuit and everything I take apart I break! I don't fancy doing this to my new car...
roadhog
Sunny Norfolk
OK, in that case leave well alone. :)
If you've been quoted 4 hours from two separate places I'd guess it's not too far out. I'm sure that when Malcolm wakes up from his afternoon nap he'll be along and tell you exactly what's involved. :)
OK I have woken up:D:D this is no easy matter,,the center condole trim must be removed,,the other snag is the gear selector module is not really made to be dismantled
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Is this just a gear knob or the whole gear stick shaft?
Illumination feed can be gotten from the nearest illuminated switch, which in most MB's is just a few inches from the gear shift.
bigasotonuk
Southampton UK
Posts crossed.
If you have a leather gaiter around the gear shift i would fit the knob an run the cable inside the gaiter to the nearest switch for the illumination feed.
If only the knob just prise up the gaiter from the bottom of the console and pull it over the knob,,give the collet nut a quarter turn and the knob comes off. the ashtray housing still needs to come out to get to the wires from the ashtray
The first post calls it a lever,,thats why I said what I did
M
meb
cls 320
Thanks, so the illumination feed would come from the ashtray? How would it connect? Excuse my ignorance..!
How long should it take for a tech to do this do you think - less than 4 hours?
bigasotonuk
Southampton UK
The Illumination feed could come from the nearest illuminated switch it does,n t have to be the ash tray. When I fitted my electric rear blind it had about a metre of cable on the loom for the switch illumination, I cut off all but 6 inches of it and just looped it off of the nearest console switch using a solder sleeve.
The ash tray is the first thing that you need to remove to get below,,so you may as well stop there and use that one
bigasotonuk
Southampton UK
I took mine to the nearest feed which happened to be a switch. Not to familiar with the CLS but surely the switches adjacent to the gear shift lever are still closer than the ash tray, regardless of wether you have to remove the ash tray or not I would just use the nearest illuminated item, as the shorter the cable the better.
The wood panels have to be lifted in order to get to the switches, and I think that the ashtray need lifting first
