PAUL GARDNER
- Oct 29, 2007
My late 2002 E320 CDi Avantgarde [which I think is a W210 ?] shows the brake assist warning light BAS on initial ignition - It stays on but will go out if the ignition is turned off and restarted - Oddly this seems to happen on cold frosty mornings only but I cannot see why it could be temp related [?]
Just watched Wheeler Dealers and they showed a similar problem with a SLK and said it was the Lateral Acceleration Sensor - which was changed for £75
Could this be the case with my E Class ESTATE and if so where is the sensor located and is it a matter of changing over the unit or will a replacement need calibrating by a Merc specialist - Thanks
