Brake bleeding kit
jibcl500
Cambridgeshire
CL500,ML55,SLK280
All
I want to buy a brake bleeding kit, does anyone on here have any products they can recommend please.
jib
Silver Arrow
Depends what you want.
E Z Bleed do a pressurised kit which enables one to do it on your own.
Or, although I have had one of the above for many years, Have one person pumping the pedal, the other operating the bleed nipples and keeping an eye on the reservoir level.
Required: One spanner, one length of plastic tube, one suitable container, (eg jam jar) and a supply of fluid (Probably DOT4).
Many years ago I put some bleed nipples with integral valves on a sports car, but still did it the old way!
George.
jibcl500
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Ive always done it the old way with a tube and a jar of fluid but just the eezybleed off ebay all in for £12.
thanks.
jib
Uncle Benz
West Sussex
Mainly Mercedes
I try to avoid the pedal pumping method wherever possible - older master cylinders too easy to finish-off. I prefer my old faithfull vacuum system. Draper do one, but you need an air compressor to operate it. Simply put, you click on a trigger and the air supply creates a vacuum in the bottle, and then clip the tube on the bleed nipple and open with a spanner. You can walk around and top up the reservoir when necessary. I will try to find a pic...
Here you go..
http://www.ccw-tools.com/popuplarge....jpg&strImageType=product&strPageTitle=Sealey VS020 - Brake Bleeder Vacuum Type
