Stompbox
- Jan 1, 2018
- Location
- Royton, Oldham, Lancashire
- C220SE Cdi 2006
Speaking of problems with carrying out work on brakes, and the mention above of seized bleed nipples - I just put my C220 CDi coupe (2006) W202 in to the local independent Mercedes dealer to get the ATF fluid and filter changed, plus the brake fluid changed - they quoted £40 plus vat for the brake fluid.
The ATF & filter went ok as did the front brake circuit. The back brakes however could not be done as the brake nipples are seized, they said, and quoted a total of £412.75 for fitting new calipers!!!! EEK.
Now as I have time to prepare and there is no rush, since the brakes are, in fact OK, it's just the fluid change I wanted to get done, can I maybe apply a penetrating and release fluid - ( I have some Looz-N-It which I've used on old motorbikes, or how about Holts Release Spray?) to the nipples at home and give them a good soaking and allow time for the fluid to work, then have a new pair of bleed nipples "on standby" to fit if the old ones won't come out without shearing?
If they do, then, with the nipples being hollow, can a bolt extractor be screwed straight in to the bottom half of the old, sheared nipple?
Has anyone here had experience of dealing with this problem?
