brake light switch and oil
andrew robinson
I was wondering if anybody knew where I could get a brake light switch for my 1962 Mercedes 220SE. I was hoping there would be somewhere in London, although I would get it couriered if further away. Not that I know anything about mechanicals, but it is the one which is on the master cylinder.
Secondly; does anybody know which is the best oil to use on this car. Should I avoid synthetics?
And finally, a source to get hold of a manual on this car if anybody knows.
Many thanks
Andrew
BlackC55
South coast
C43
A MB dealer can get you the parts you need. A good quality 10w 40 should be fine.
David Nock
South Yorks
CLK/2009/320CDI
I still use Castrol GTX or Duckhams mineral oils in an old rotary. (Which shouldn't have synthetics in it).I change it frequently since it's a fraction of the cost of synthetic. Castrol even have a range for older engines (which doesn't suit me because it closes up sealing spaces), this oil may well suit your car.
I don't know of any reason why you should avoid synthetics. Maybe someone else has a view?
