brake lights stuck on
whitelockben
Not the switch that's been check. Any ideas? Common wiring? Really need help ASAP!!!!! Its a w208 200 n/a
When you say the switch has been checked,,when it is unplugged are the lights still on
W
whitelockben
No, the resistance over the 2 x three pin arrangements was measured with the switch open and closed. Any ideas other than the switch?
I cannot see it being something else,,you cannot measure it with an ohmmeter, thing to do is to pull the connector off
Cole@MBS
www.mbssouthampton.co.uk
Have to go with Malc here, the power to the lights run through the switch, cant be anything ease on a 208!
