brake squeal
Discussion in 'Suspension, Steering & Brakes' started by gary r, Nov 5, 2012.
  1. gary r
    gary r Senior Member
    105
    Apr 25, 2012
    southampton
    Your Mercedes:
    2006 55 plate slk 350
    i am getting terrible brake squeal at the moment its coming from the rear discs and only when i am reversing. Any ideas
  2. EmilysDad
    EmilysDad Senior Member
    8,937
    2,521
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    ML350
    Just drive forwards! :rolleyes::rolleyes::rolleyes:
    Reversing AND braking? Or just reversing? :confused:
  3. television
    television Always remembered RIP
    164,074
    290
    Your Mercedes:
    Probably just a lack of grease on the rear pads, is it important
  4. CafeMB
    CafeMB Banned
    51
    Oct 23, 2012
    Grantham, Lincolnshire
    Your Mercedes:
    Mercedes S320 CDI
    Have you checked if there's any grit stuck between the pad and the disc?
  5. television
    164,074
    290
    Your Mercedes:
    That would not cause a squeal , it would make a grinding sound
  6. CafeMB
    CafeMB Banned
    51
    Oct 23, 2012
    Your Mercedes:
    Mercedes S320 CDI
    I disagree, that's if there were lots of grit spread around, if it is concentrated on one spot it would squeal as the pressure would be concentrated on a single spot.....
  7. television
    164,074
    290
    Your Mercedes:
    It is the surface of the disc on the pad that makes the pad resonate to produce the squeal. Pads are far to hard to get any grit in the surface.
    But that is fine by me if you wish to disagree :D:D
  8. CafeMB
    CafeMB Banned
    51
    Oct 23, 2012
    Your Mercedes:
    Mercedes S320 CDI
    But it is possible. The pad is a softer compound than the disc after all.
  9. television
    164,074
    290
    Your Mercedes:
    Its up to you, the pressure on any grit would soon crush the what ever it was and again grit cannot cause a squeal, it would make a grinding sound
  10. OP
    gary r
    105
    Apr 25, 2012
    southampton
    Your Mercedes:
    important no very annoying yes
  11. television
    164,074
    290
    Your Mercedes:
    All you can do is to remove the pads, re grease them and re fit, sanding the disc may help, another thing is the rear brakes only get 28% of the braking force, you could try a few very hard stops to see if t goes away
  12. spock500
    spock500 Senior Member
    890
    Apr 5, 2008
    Milton Keynes
    Your Mercedes:
    300TD, 1998
    I find a good jet washing (pressure wash) with the wheels off helps although only for a month or two.
    Malcolm's suggestion is probably a better long term fix.
  13. star
    star Forum Supporter Authorised Forum Supporter
    5,474
    936
    Oct 6, 2004
    Reading
    Your Mercedes:
    Smart + others :)
    Genuine or aftermarket pads?? :)
Share This Page
