Hi, new to this forum as a member although have used it for obtaining some very helpful i fo in the past.
I have a 2006 CLK 320CDI. My issue is that the brake wear warning message wont go away. New pads AND new sensors fitted, expected the message to disappear as it had in the past after previous replacements, but on this occasion, neither front nor back pads were worn and sensors were not in contact with the disc - but since I had new pads and sensors I fitted them anyway! So, having perused this and other forums for info on more subtle reasons for this (eg damaged wiring to SAM, or bad SAM) but came up empty. So, decided I needed to post this in thehope that someone else has experienced and fixed this issue. I am a degree qualified electronics engineer so have no qualms about delving into the vehicle electrical system. But I cannot find any info on where the sensors connect into the rest of the car electrical system. Anyone have a wiring diagram that may help? Anyway, ny main concern is that now warning lights (and I assume messages) are automatic MoT failures - despite the fact that the brakes themselves are all A1. Anyway, any inputs gratefully received. Thx
