- Aug 4, 2016
- Location
- Sunny Essex
- W211/E320cdi/2009 and CLK200k 2009
The CLK has developed some low speed knocking noises over uneven surface ,( possible more prominent when turning ) . Also a pulsing vibration when braking .
I have taken a couple of pics after examing the car.
The first pic shows the antiroll bar where it goes through its bushing , the car is jacked up on one side when the pic was taken , and you can clearly see a gap which is either wear related or is it becaus the car is jacked up ? Having done some reading , the antiroll bar needs to come out anyway to replace the two control arms on each side so it might be worth doing anyway ?
The second pics shows a split i found in one of the rubber gasket covers so one of the arms is certainly due replacement , this may have split because of excessive movement/wear in the ball joint ? On a ten year old car maybe both control arms on both sides are due replacement anyway .
Looking at youtube , the replacement of both control arms looks fairly straightforward , i may need a couple of bigger spanners .
Prior to the braking issues/knocking developing after doing 2000 miles in France i was already planning to change all 4 calipers for refurbed ones due to uneven brake pad wear and pad overheating .
Ive ordered a set of Brembo pads/discs from ECP in case the pulsing whilst braking is caused by uneven disc wear due to sticking pistons . I was thinking about returning these if that wasnt the case but if i end up doing control arms and calipers i might just as well fit them and be done with it .
So i guess my questions are :-
1) Is it worth changing all 4 control arms if one has failed because all the others wont be far behind .
2) change the antiroll bar as well because of the bush wear in picture 1 , and because its coming off to do the control arms ?
3) Can ball joints and bushes be changed seperatly on the control arms ? Or do i have to buy the complete arms ?
4) Buy MB parts (not sure on costs , but they would fit well) or someone like Lemforder ? (Any other recommended makes ?)
Any other comments or advice would be appreciated
