balge59
- Dec 5, 2005
- Location
- Nottingham
- 1993 190E 2.0 Automatic
http://forums.mercedesclub.org.uk/album.php?albumid=165&pictureid=1110
Well the story is - reversing up hill in a tiny carpark (due to some numptys' bimmer parked like a 3 year olds tricycle...), big bang, no more go - looks under the car to see the above mess. Also picked up a snapped bolt and two large steel/rubber 'washers' -unfortunately lost now
Further examination at home shows the flexible coupling disintegrated and apparently not much other damage - CV boot (?) ripped on the passenger side, ABS sensor cable, few bangs and knocks.
What I'm wondering is - will it be worth just replacing the flex coupling and boots or is there any other problems likely - as it happened at below walking speed will it have bent the propshaft or something? What should I be checking?
Also, what does the bolt screw into, will there be a problem if it needs drilling out or such? I think the 'washers' are spacers off the broken bolt, which is supposed to hold the diff up, right? Cant find an assembly drawing for it yet...
cheers!
cheers!
