Buying a 2001 ish CL500, need pointers
The German Flower Pot
Cambs
www.turbo-babes.co.uk
  • #21
cheers Malcolm, i did not even think about Top Marques, as always your a mine oif info & no doubt sparkly stuff for the ladies
is your inbox as stuffed as a very stuffed thing?
I forget that I have an in box thank goodness,,, you will find a genuine car,,,remember that marks in the inside are very expensive to put right, do check that everything works, I am sure when you have narrowed your search down there could be an indie that would look over it.
Cambs
  • #23
ive just renewed my insurance
was £390 with aviva but on renewal went to £1,200
so went with halifax for £380
asked halifax about a 2001 cl500 and they said £1,100!
im 41 not 1 ffs with no claims since 2005
Frontstep
T210 320cdi
"the car had a complete bare shell re-spray by mercedes in 2010 as it had a spot of rust on the rear wheel arch so under warranty the whole car was re-sprayed, is this a lie or a slight exaggeration as why would they do the whole care back to the shell?"
If it has had this work done then it will be documented with Eskulab but I doubt it.
"Eskulab is a german abbreviation for elektronische kulanzabfrage.
which stands for 'electonic fair-trading queries" C&P
Cambs
  • #26
need some help
on my w124 coupe i can get my chair all the way in once the doors is open fully, ive just had a mate bring his CL500 to my house and the doors look fully open but the angel is much MUCH less than than both of my w124's!
i can just about get level with the back of the seat let alone the front
is there some catch or some such thing to open it more as its very very narrow
im sure you are thinking i did not open it fully but we did
i know the w124 bonnet opens half the way then you hold in the 2 buttons and it goes all the way up to 90 degrees
ill be gutted if i cant as the car is stunning, dark met purple, black leather with dark brown wood, stainless exhaust and 97,000 miles with a full respray by merc in germany 3 years ago (might have been 2) for £5,500
The CL has a cantilever door hinge action, I thought that they opened quite wide, there is nothing to let them open further
Cambs
  • #31
cheers malcolm but i use the doors to hold on to as i shuffle my huge carcus in and out, it only needs to be about 10 degrees more to get that bit closer
thanks for looking
www.W140.co.uk&www.r129.co
