Buying guidance expected
Tharaka
E320
Dear all,
I'm planning to buy a Mercedeze E 270, 280 or 320 CDI with manufactured year 2008. The mileges I can afford are 300 000km . Is it safe to buy this mileged car? If you can share your thoughts or post from this forum, I am much grateful.
Thanks for the support provided here for the community
Hello and welcome
They only made 280 and 320 cdi’s in 2008
Where are you based?
tjamesbo
Sutton Coldfield, West Midlands
1999 CLK430, 2007 VITO 3.0V6 , W124's (1994 320TE , 1993 220TE ) , 07 2.5 X-Type
300,000 Km is nothing for these cars the key thing is has it been well maintained and serviced , suspension wear and tear items replaced drop links / lower arms ARB bushes etc has the Auto gearbox fluid been changed they should be good for 550,000km if well maintained check that its a non SBC model the lifed SBC braking system was deleted around then sometime ?
Late 2006 with the facelift SBC was dropped so a 2008 car should be fine
Frontstep
T210 320cdi
It's all about maintenance and not necessarily Main Agent as some of them just do the bare minimum.
They can be very expensive to fix so as comprehensive a pre purchase inspection as possible and with a ramp is important.
Do you have a specialised independent Mercedes garage near you to look at it ?
T
Tharaka
E320
Hi thanks to all, may be I need to check with the authorized service agent. Another thing , is the four wheel drive version is very expensive to maintain?
Frontstep
T210 320cdi
We tend to prefer independent specialists here, the Main Agents as we call them are often overpriced and
not very helpful if they can't give you a big bill.
I would guess the four wheel drive is expensive to maintain, fix and with fuel.
Your winters make it much more useful, I only see snow every few years and it doesn't last.
T
Tharaka
E320
Of course yes, that's the main point. We have around 4 months without snow. By default we have snow.
Frontstep
T210 320cdi
I don't see them as a good vehicle for the snow.
Tel: 020 8863 9233
