C 220 Cdi 2003 Car Not Starting
mitch1981
Starter Motor Is Ok But No Response From Engine As If Fuel Is Not Getting Through, Glow Plug Light Has Been Staying On For Upto 1min Sometimes But Not All The Time, Also Found Resovoir To The Right Of The Engine Under Plastic Cover Which Is Low On Some Sort Of Oil Possibly Linked To Fuel System, But Dont Know What Should Go In It, CAN ANY ONE HELP ME GET MY CAR WORKING AGAIN THANKS
colechelle
Resigned
go for a injector all day long, have you had any fault codes read???
Xtractorfan
S class
Have you checked the fuel filter doesnt need changing..
dava
The Toon
Thats the power steering fluid, on the cap is a dip stick check it using this. As some one elese said high possibility it's an injector, spray a small a mount of aero start into the intake, if it fires up then more than likely one at fault. You will need them spill port tested to distinguish which one, or more are at fault.
John Kerr
Nr Folkestone Kent
W209 CLK 220CDI Sport
same thing happened to me a while back,Turned out to be the feed pipe from the tank had a pin hole in it . No sign of a leak because pipe is on the top of the tank.Hard one to find.
M
mitch1981
thanks for the help i will try these, do you think the glow plug light staying on sometimes is anything to do with it
M
mitch1981
After the car has tried to fire up there is a buzzing sound coming from the left hand side of the engine then it stops after 20sec, when the ignition is on theres a buzzing sound from the right side of the engine near the power steering resovoir is this normal
M
mitch1981
Hi, I've had it tested and all the injectors are fine the only fault is a glow plug is not working and the mechanic said this wont stop the car from starting, he said it could be the Fuel High Pressure which he's going to check this week has anyone got any more ideas, thanks.
M
mitch1981
Would a leaking injector show up on the engine management as the mechanic said the only fault was a glow plug but today he said an injector is leaking, i was just wondering if this should of shown up yesterday on the engine management
hmang
leaking injector sounds very likely for your problem.
motor cranks but won't start.....you might find it will fire up after 3 - 6 cycles...wont do battery or starter much good though.
mine was worse after a run but not too bad from cold
colechelle
Resigned
you need a leak off test, thats the only correct way of telling if the injectors are passing!!
hmang
as colechelle
you can make the kit to do this test using
4/5/6 return fuel pipe unions
4/5/6 equal lenghths windscreen washer pipe
4/5/6 syringes from local pharmacy
don't forget to clamp your return pipe after the last injector.
you may not get the merc values but will soon see if one is returning a noticable amount more than the others.
be careful of fuel spills
marios
New Registration
london
22ocdi ML320
C220 cdi 2003 not starting
HI my mercedes is not geting any fuel from the diesel tanks , can anyone help please
