I have been recomended by a fellow site member to check that the return pipes of the fuel system are checked to make sure I have no leaks,as I have a strting problem.Is there an easy way to check the pipes and is there a particular area I should be looking at for problem,I have changed injectors ,rail seals,low pressure pump,still have problem starting when car is left over night,I have to turn over the engine for aprox 2 mins before it fires up,it,s then ok all day but next mourning it won,,t start
any ideas.
any ideas.
