C Class 220d 2015 - Squeak from wheels when steering.
Euan Geay
C Class 2015 220d AMG Line
Squeaking coming from both wheels when steering, particularly at low speeds. Have bought the fluid to top up the power steering reservoir but cannot seem to find it and no info in the manual - anyone point me in the right direction or am I addressing the wrong issue anyway?
Cheers,
Euan
Are you getting the squeaking from the inside or outside>
E
Euan Geay
Outside, particularly from the drivers side wheel.
Wabby
MY17 C250d Coupè
Are tyres low?
Is it a hopping sound, like the GLC issues?
sonixtorm
CLK 320
Cheers,
Euan
I’d double check the tightness of the wheel nuts (well, bolts technically) if you haven’t already done so.
Any chance you can record the sound? Might be tyres setc.
Oldspanners
Normandy
C CLASS 2004 C180
Have a look at this video it could be a ball joint.
E
Euan Geay
Thanks for the feedback, will see how I get on checking above and let you know.
Cheers.
coventryslk
Coventry
W204 CDI Sport
Turning the tyres on a smooth surface? Smooth/painted concrete or smooth new tarmac?
ernieh
Scotland, East
Cheers,
Euan
Think you will have electric power steering, so no reservoir. Sorry can't help with the fault, though.
Ernie
HaydnM
Newark , Notts
Mercedes ML350 / W164
Check you do not have a lip on the front Brake disc’s
Turning the steering puts slight pressure on the brake hose, just enough to make the pads kiss the disc, if you have a lip on the disc it will be that rubbing on the pads
Uncle Benz
West Sussex
Mainly Mercedes
Most likely the bottom ball joint. It is part of the lower arm. I've changed quite a few of these on w205 c class for this squeaking issue. Becoming very common.
