halex
- Oct 19, 2022
- C-class, S204, 2010 year, 200CDI
Hello,
Have S204, C-class, 200CDI, year 2010, around 360.000km (or 225.000 miles) and all is great, but I would like to know how you can check if clutch is at the end of the life and need replacement?
To me, shifting is good, don't see any problem, maybe only when I need to start moving sometimes it shuts down, but I was thinking that I am the problem - I am pushing slowly gas pedal and releasing slowly clutch. When I am not touching gas pedal and only slowly releasing the clutch it is much better, car starts going normally and when clutch is almost released I can put my foot on a gas pedal normally to use this acceleration. Is this the sign I need to replace it?
One more question regarding the diesel injectors... I gave them to be refurbished (cleaned) and after putting them back one was occasionally giving error that needs to be reprogrammed again. I bought new OEM Delphi and replaced it and all is good for now. Should I replace all other three that are old and original with the new original ones as a part of preventive maintenance or to wait if some parameters on STAR diagnostics show that some parameters are not perfect (trigger for replacement)?
Noticed also that left hinge on a trunk door has some small start of corrosion where the bolt is - what spray I should use to clean this and prevent spreading of it?
Thanks for the answers.
