c_class_paul
New Registration
First post, so please forgive me if it is not detailed enough or too detailed. Have searched the forums for a similar problem but not found one.
C Class C220 CDI Saloon, Dec 2002, 54,000 miles.
Sometimes the car is difficult to start - always the same symptoms:
* Turn the ignition key to the sprung position
* Dashboard self check lights come on, as does glowplug lamp
* Then nothing - no starter motor
Eventually, it will start (with me holding the key in the sprung position) but taking between 30 seconds and 12 minutes. I also turn the key back and take it out and try again sometimes.
The fault is not constant - it shows the above fault, and then will continue to be difficult for a few days, then fix itself before appearing a few days or weeks later.
I have kept a logbook of when it happens, and cannot see any pattern for:
* Date patterns.
* Outside temperature
* Time since last driven
* Wet or dry weather
* If car is parked on a slope or flat
* Amount of petrol in tank
The only common factor is it rarely happens after the car has been driven for 15 min and I try and start it soon after.
I have been to two dealers, who have checked the car over (charging me £50 each time) and each say no fault is found. There is nothing in the ECU log. I have not been able to replicate the fault in front of a dealer.
I have checked the obvous things - wiggling the automatic gears around in case the sensor switch is faulty etc.
I have been living with teh fault for about a year now - but the first time it appeared it hapenned once and then was OK for four months - it is now getting more frequent.
So, anyone seen this before? Any suggestions as to my next move?
Thanks,
Paul.
* Date patterns.
Thanks,
Paul.
