marcus gp1
- Jun 23, 2006
HI hope someone can shed some light on the problem I am having with the brakes on my C- class 2ltr auto Elegance. a couple of weeks ago I reversed the car out of the garage and noticed that the BAS-ESP-ABS lights were still on when the car was running. Done a bit of research on this forum and hoped that it was the problem with the brake light switch, fitted a new one but no luck. My cruse control and speed limiter still work, and to some extent the ABS still works but only at the last part of the braking process, so I checked the rear pads and found that both rear inner brake pads had come away from the backing plate so I fitted a new set, and the ones that came out were genuine Merc parts and definitely did not have brake sensors in them. Fitted a new set of Lockheed's and the rear disc's are in very good condition, went together no problem but the light's are still on on the dash until I crank the engine into life. So it looks like a fault with one of the wheel /ABS sensors, unless someone knows better? not looking forward to going to the dealership to get it diagnosed. Anyone have any suggestions.
