Mickey76
- Aug 16, 2012
- Location
- North Yorkshire
- 2003 E320 Cdi S210 145k
Thanks David. That is the first diagram that I've come across that I can understand. It happened again yesterday afternoon. It is the first time it has happened during the day. It start and ran perfectly in the morning but decided to throw its hand in after standing for about 8 hours. This morning it started on the button. WHY???? If air is being drawn into the system I would think it would happen all the time. It's a bugger. If I put it into a garage it might be days before it happens again. I wonder if it could be identified on a diagnostic test. I have had them done before (No joy) but not on a Star which is difficult to find in my area. I have been told that the Snap-on system is just as good. Has anyone any experience of it.
Thanks again to all you guys out there.
John
Snap-on diagnostics are pretty good, still need someone in-the-know to decipher the codes.
Had new fuel pipes, o rings, pre filter, fuel filter- last owner (& new starter!!)
I've done delivery valve seals and new fuel pipe o rings
My clear pipe to pre filter completely empties of fuel, starting it is getting worse, can't leave it on flat or facing uphill as won't start upon return.
Will try leaving fuel cap off, wil replace filter o rings, can heat exchanger take in air?, there are no leaks visible.
Sympathies on frustration!
