C180 flashers , wippers and hazzards
Armand C180
On my 1994 C180 I have intermitent problems (obviously related because they are simultaneously) with the flashers and hazzards and with the wippers, but only on their first speed. After a while everything is back to normal , and so on....it is very frustrating!
Could anyone give my a piece of advice...what should I check or replace?
I have also an intermitent staring problem, but this started a few years ago, the fuel relay doesn't always start at the first turn of the key...could this be related?
Any help would be greatly appreciated!
roadhog
Sunny Norfolk
W124 300D x2, C124 300
On my 1994 C180
Think yourself lucky! When I drive down the road people stop and point...:D
Sorry can't help with your original problem. My guess would be the control column stalk. My wipers sometimes play up and it seems to be the switch.
Dec
Ireland.
W202
It could be the stalk switch or more likely in your case a relay, however I don’t know much about the relays, there are 3 in picture but I am not sure which is which, someone else may know more than me.
You could remove and clean the terminals with switch cleaner, this may help?
You could also inspect stalk, wiper section. Let us know how you get on.
Dec
www.W140.co.uk&www.r129.co
