C180 sport W202 humming noise !!??
secunda
north yorkshire
Merc C180 sport W202. have recently come across a permanent humming road noise that increases/decreases with speed, i have got new tyres all round, have today jacked up the beast and checked break wear, play in wheels and noise when i spin each wheel.....all ok ! i have checked tyres in case i have picked up a nail etc....all ok.......any advice please ??????!!!! :(
the car handles and performs fine.:cool:
This should be just a wheel bearing. very hard to detect by hand, you can jack the car and by rotating the wheels sometimes feel the slight roughness or the balls, by opening the windows its more easy to pinpoint.
Malcolm
secunda
north yorkshire
Bearing !!
Malcolm
THANKS TELEVISION. I HAVE JACKED UP THE CAR AND ROTATED THE WHEELS TODAY AND THEY RUN FREE WITH NO NOISE OR PLAY........ !!!!!!?????:confused:
i HAVE ALSO BEEN ADVISED THAT U R THE MAN TO ASK ABOUT MY OTHER THREAD REF ENGINE REVS ?!
THANKS AGAIN
Iain the gadget
Edenbridge, Kent
W208 230CLK W163 ML270cdi
Does this dissapear when you turn the radio up?;)
Just jesting.
I agree with TV. Wheel bearings are notoriously difficult to detect in the early stages. Snap on sell an electronic stethoscope for this purpose. Just keep an eye on it (or should I say ear) and see if it gets worse.
secunda
north yorkshire
thanks
thanks all for the advice.....is changing the bearings an advanced diy job ??....or a job for the shop ??:-|
secunda
north yorkshire
Just jesting.
thanks :rolleyes: ...i turned up the radio and the noise went away......amazing !!! ha ha :grin:
Just in case the radio goes wrong.
jack car remove roadwheel. Unbolt brake calliper and surport or tie it up so that the hose is not strained. Remove dust center cap. remove clip or pin holding the center nut or clamp,if clamp loosen. Unscrew nut and the hub will slide off. Remove the faulty bearing and wash center of hub out.
Re fit.
If the bearing is tight,do not hit it. simply place the bearing in the freezer for a couple of hours and warm the hub, the bearing will then fall into place. (Note that the magnetic side must face inwards otherwise no ABS) refit to the hub carrier spindle. Replace nut or clamp and tighten till the hub cannot be turned,then back off so that the hub turns freely, tighten clamp and fit clip or pin (if pin renew) pack the hub dust cap with high temp grease and tap on. Re fit brake calliper using new bolts (saftey issue). re fit road wheel.
Drive down the road with the radio off to enjoy the silence that an MB can offer.
Malcolm
secunda
north yorkshire
thanks television !!!
thanks again....ill give it a go at the weekend .....:D
spock500
Milton Keynes
300TD, 1998
Re fit.
Malcolm
Apart from the hub cap do the actual bearings need packing with grease or any additional lube?
Thanks,
