C180 W202..rev Out 4000rpm
secunda
north yorkshire
My c180 w202 auto. when i put my foot down and the car reaches about 4000 rpm in each gear, it sounds like the engine is at max revs and kindof stutters. it is as if you put your foot down when in neutral and keep to redline.....this is a hard one to explain !!!!!:confused:
Iain the gadget
Edenbridge, Kent
W208 230CLK W163 ML270cdi
There is a limiter set to about 4000 when you are in park or neutral to stop damaging the engine. So I guess there may be a problem with that function if it is doing it in gear.
Perhaps a diagnostic would show it up. Maybe it's the pesky brake light switch as I know this causes all sorts of problems with otherwise unrelated issues.
Television might be your man to answer this.
Good luck and let us know the cause
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
I,m sure i,ve read somewhere on another forum something similar to this and they reckon it was caused by a faulty E.C.U.
Get the car plugged into a diagnostic
Any one else any idea?
secunda
north yorkshire
Thanks for the info......ive got a codereader and a codereader bible on its way from the good ol US.....we`ll see wot happens.:)
www.ckinsurance.co.uk
