Septic
Hi Folks
got a revs problem with my c180 w202 1999 originally the problem was that when i started the car the revs would fly up to 30k rpm then drop below 5 and cut out
after the car had warmed up from driving the idle would be a bit over 10k
and the throttle peddle would be very sensative. I disconnected the wiring loom that comes from the throttle body thinking that it was a throttle position sensor (within the body) problem tried the car when driving its fine. So i replace the throttle body with a second hand one took the car for a drive
but still have the same problem. Ive no idea what to check next and its proving quite a challenge to drive the car when it want to idle a 10k and the slightest touch of the throttle pedle sends to car into warp.
Any help would be great.
Thanks Stephen
Thanks Stephen
