brypat
- May 22, 2013
- Location
- Cheshire, England, UK
- C200 1996
Hi, I have a 1996 Mercedes C200 which has only 1 of the two negative outputs for the coil packs working on the PMS unit. Both circuits & coil packs work fine when used with the good output. Does the unit rely on just one pulse of the crank sensor every 360 degrees to trigger both outputs - I am trying to find out if there is any circuit/sensor supplying the PMS which would cause only one coil trigger output to work before I send the PMS unit away for a very expensive repair! Your knowledge will be greatly appreciated, Many Thanks, Bryan
