c200 auto bas asr abs light ?
db69
hi all about to put my c200 auto petrol 1998 back on the road but the bas asr and abs light is staying on , when driven it will not change up out of 2nd (i think) , also can not turn off asr with the button on the dash .any one got any ideas please on how to fix it ?:p
Either low voltage to the pump or a speed signal is missing, do the lights come on when the engine is running and before you have moved the car
D
db69
they stay on from turning the ignition on ,cheers db:p
First thing is to make sure that you have 12 volts going to the pump, you could have an OVP relay on your car and these fail
D
db69
by pump i presume you mean abs pump?:p
Yes I do mean that, your car is a later one and should have the OVP relay fitted
benz-rider
hi, i have a c250td auto which i believe had the same problem, the car was stuck in "limp home mode" and only used 2nd and reverse gears as a result of a faulty ABS sensor in the diff , the part was 70 quid and an indie MB garage fitted it at a total cost of £180.
