PChinnery
I have just replaced the head gasket on my C200 after it failed while on holiday.
After this work was completed the auto gearbox has started to snatched into gear on change up. It is still reasonable smooth when changing down, the problems also appears worse when the car is accelerated slowly. If I boot the car from a standinging start the change is reasonable. Before the head gasket replacement the gear change worked fine.
When the car failed it was pulled on to a low loader with a winch, could this have damaged the G/B or torque convertor.
I have owned the car from 80K miles and don't think the G/B or fluid drive oil have ever been changed. The car has now covered 109K miles (and towed a caravan for the last three years).
Do you think and oil change would cure this?
Any other ideas?
Regards
Paul
Any other ideas?
Regards
Paul
