C200 Door panel removal
Shanusacarabus
Leeds
Hi all, kinda emergency here as the sun is going down, how on earth do you remove the rear door panel as my window has just fallen off inside ???... no screws visible at all ???
Please help !!!
sun still blazing here! is your car a w202 or a w203?
Shanusacarabus
Leeds
Its a W203...... i have kinda worked out the screws behind door handle and rest are just those push on clips... dont know what it was but i have half fixed it now... couldnt get the top screw out tho as i couldnt get torque bit in smaller hole grrrrrrr
whitenemesis
CLS55 AMG '05
Probaly too late but..
Shanusacarabus
Leeds
Thanks for the help guys..... i did the job ( kinda ) but the window timing is out now..... when window closes it re-opens a little ( like when a hand is in the way )... any ideas how i can cure this ??
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Disconnect and reconnect the battery and re-synch, though by doing this you will have to do all 4 windows and possibly the sunroof also make sure you have the stereo code.
It might be better if you were to disconnect the individual window motor as I believe damage "can" be done to the SAM unit on 203's by disconnecting the battery.
Shanusacarabus
Leeds
Thanks for that info... just how do you re-sync windows though???
rpe2
Silchester
Turn ignition on, hold window button in down position for 10 secs, release, hold switch in up position for 10 secs.
Should be job done.
To sync the windows, you just close the window and hold the button in the up mode for 10 sec with the key turned to 2.
This should solve it unless the window track is too tight
Remember guys when telling people to disconnect batterys on these 203,s, it could easy cost them a rear sam due to the advise given to them!!
Shanusacarabus
Leeds
Just tried the 10 second thingy ( without disconnecting battery ) but doesnt seem to work.. maybe im doing something wrong... or does it need power interuption. Not sure what this SAM is but im guessing its not good.. or cheap !!
The window will be too tight in the tracks, and it goes down as it thinks that something is in the way, does the window slow down when it gets near the top
Shanusacarabus
Leeds
No not at all, it remains at a constant speed, as u say.. as if something is in the way
I can send you the instructions for the window motor, but before that it may pay you to unplug the electrics from just that motor to see if it will re set
Shanusacarabus
Leeds
Ok, ill try that when i have a lil more time to remove the door cover again
An alternative would be to remove the window fuse,and re fit. this is far better than a battery disconnect on a 203
Shanusacarabus
Leeds
Thats a great idea... cheers malcolm, ill dig maual out and see which fuse it is
