C200 Kompressor Issues
Ziggy122
We have a C200 Coupe Kompressor (03 plate)
First problem is the Dash is alerting to a SRS Failure (Air bag and Seatbelt Explosives?)
Is there any things we can try to see whats causing the fault?
We tried a Free Diagnostic On it (digimoto) but didnt find a fault with it
Is it a case of a fault code needing to be read?
Problem No2
The Passenger Door has recently started going Wild when you Press Lock/Unlock on the remote
Instead of just unlocking/relocking the door, the "motor" works for about 2 seconds longer then it should
In the mean time the Door Knob becomes a Piston really
Is there anything That we can do to cure this? as when u unlock the car it doesn't always open the door
Problem No3
The Light Sensor - on Cold Mornings this regulary pops up
Like this morning, it wasn't frosty outside but cold - and the error popped up
Problem No4
Possibly Linking No3, The ESP Light Flashs on the dash as well saying its Not active, after engine has been on for 2 mins, this one clears, again is this just a cold starting issue?
Any Help Would Be greatly Appreciated
Ziggy
Steve@Avantgarde
Bristol/Somerset
You need to find a good indie with a Star diagnosis machine to help you with these faults as most other diag machines wont read all ecu's fitted to the car.
Your door lock bouncing is likely to be a faulty lock actuator motor. The other faults will need diagnosis with star.
Where are you so we can recommend a good indie?
T
The mallard
Interesting, my C200 coupe on a 53 plate also triggers the light sensor warning on first start of the day and sometimes the srs which sorts itself out in 3-4 seconds. The light sensor malfunction can be cleared by switching off and restarting the car. I first noticed in in the colder weather but becomming more prevelant. I suspected low voltage and replaced the battery but still does it. I am having a star analysis soon so will report back
Z
Ziggy122
North NottinghamShire - Near Junction j27,28 on the M1
There is a Company just a short Drive away Called Neil Harrods, There website say they have use a Merc Star Machine
Would they be ideal?
As for the Door Actuator - how easy is it to disassemble the car door inside to access it?
Ziggy
