Doo-da
- Nov 10, 2012
- Location
- Newport, wales
- C200k 2003 1.8 271
New memeber saying hi with a question for the techs on here..
Just aqquired a 53plate c200 k 1.8 with a misfire, was too cheap to let it slip away in all honesty...
History of the car is,one owner, serviced on time by the same garage since new, with oe parts , cost hasnt been an issue until now.,
Has run fine for its 164k miles, until 3 weeks ago.
The car starts on the button and runs perfect until warm, then the misfire appears, ticks over sweet, but under load it misfires on cyl 1 .
Parts fitted to try to cure it before i bought it are
4x new bosch coil packs
new plugs
New upstream llambda sensor
new Breather hose from block to inlet man
Throttle body has been cleaned out, and an inlet cleaner run thru whilst running.
Theres no traces of oil in the loom at all.
Only 2 codes stored are misfire on cyl 1 and mixture adaption limits reached
ANy ideas guys
daz
new plugs
ANy ideas guys
daz
