N
NatD
Hi All, have issue with poorly C200k, auto. Car has done 80k and is due a service.
Starts fine every time hot or cold. But when engine warm/hot the idle often (but not always) goes rough, very rough and the car drives terrible under 2000 rpm.
If you rev it between 1000-2000 rpm the car judders, splutters and shakes like mad, as if its only running on 2 cylinders.
Above 2000 rpm it seems ok again until you come to a stop and the idle is jumping all over the place like it’s going to stall (hasn't yet). Engine light is on so I borrowed an ODBII reader:
ODBII Errors:
P0171 - System too lean (Bank1)
P0301 - Missfire Cylinder 1
P0302 - Missfire Cylinder 2
P0303 - Missfire Cylinder 3
P0304 - Missfire Cylinder 4
I cleared the codes and tested over a few days. I get various combinations of these errors back if I drive the car for 20mins+.
The most consistent code is P0171 too lean but often there is more than just the one.
I know there are various posts on forum like this but none of them ever have a successful conclusion ( that is written up on the site. Perhaps this can be the first, fingers crossed!
So I have started work...
ACTION1: Checked then replaced plugs with like for like BOSH Iridium’s.
RESULT: No difference, error codes still pop up
ACTION2: Replace air filter.
RESULT: Car feels sharper to accelerate and more responsive. Initially was hopeful, but no, errors still appear.
ACTION3: Purchased some MAF cleaner... but not used it yet (job for tomorrow)
RESULT: TBC
Clean MAF, job for tomorrow. Looks a little awkward to remove but should be fine. Reinstall and test.
If the MAF clean didn't work I was going to replace the fuel filter. It’s cheap and looks an OK job to complete. I have run it very low (zero miles left on clock) a couple of times, but I have never 'run out' to a stop.
THEN WHAT?
Assuming I do the above and I still have the issue what else should I be looking at next? (Apart from going to my local MB 'Stealers')
Would really appreciate any advice / comments / suggestions as I think I will be pulling my hair out if I can’t solve it this weekend…..
NatD
ODBII Errors:
RESULT: TBC
THEN WHAT?
NatD
