Hi
I am new here and I hope you people will be able to help me.
I have a just purchased a 53 plate CLK270 but it has an air con problem. I have had a technician look at it and we have two problems:
1. The right hand side mixer motor only seems to blow cold when running but when you carry out an auto reset it actually blows out warm air for a few seconds when it is on its cycle. The right hand side temperature adjuster does not seem to do anything
2 There is a connector underneath the Parktronic indicator which connects to the side fascia vents and it has no wire going to it. I presume there is a wire supposed to go to it. If so where does it come from.
Thanks in advance
Thanks in advance
