s and k autos
- May 27, 2009
- Location
- middx
- 320 SL 300 E 124 SHAPE
hi all does any one know how to put hydlic oil in the gearbox pump
If you mean automatic gearbox box fluid, you pour the MB fluid down the dip stick tube
this is a semi auto box it doest have dip stick i think
It will be a fully automatic 772.6 box on a CDi
You can only use MB fluid
You can make a dip sick from curtain wire should be 5.6cm up the wire when hot and in D
its a six speed troptoic box it does not have a pan under the box we replaced the hydlaulic pump but we dont know how to put the hydlaulic fulid in thanks
This is the box minus the sequential bit
http://www.detali.ru/cat/oem_mb1.asp?TP=1&F=203208&M=646.962&GM=716649&VIN=*&CT=GM&Cat=65Z&SID=26
