Hi All
I have been meaning to join the forum for ages.
I own a well maintained merc c220cdi coupe auto (2001)
I have had the car for the past 4 years and not had any problems with it until now!
I have had the car to a few garages about the problem with unsuccessful results.
The problems are increase use of fuel, i normally get around 50MPG but only getting around 43MPG (on a good day) around 60-70miles less on a full tank.
When the engine is cold you can put the accelerator pedal to the floor and it will change down a gear as normal and accelerate away.
When the engine is warm after 15mins or so, when are going around a bend or driving up a slight incline in a low gear, you but the pedal to the floor to change gear – nothing happens. This happens in all gears (a very slow increase in speed)
You want to overtake – you change gear by pushing the gear stick to the left (to change down a gear) it will only let you rev the car to 3000, it want let you rev over this.
It feels like the when you are pushing the accelerator pedal down its not opening all the valves.
The air flow sensor (i think its called this) has been changed 2 weeks ago.
Can some help??
Stu
Can some help??
Stu
