C220 CDI Headlight bulb replacement
duncanh
Wiltshire
BMW 520d SE F10, formerly c220cdi estate (for 12.5 years and 345k miles), before that w124 and w210
There is a plastic disc at the rear of the headlight that clips off. Push the clip in and pull off. You can then pull off the connector from the bulb.
To remove the bulb, there is a small wire clip holding it it place. If I remember correctly, push in the top of the clip, move it 10-20 degrees towards the drivers side, and it will unclip and the bulb can be withdrawn.
Reassembly is the reverse of this.
O
oldmoondog
Thanks very much - worked like a dream!
