C220 CDI starting problems....when warm..
slimandylincs
North Lincs
W Reg C220 CDI Estate (The Lady of the House's Car) Subaru Forester 2.0 XT converted to LPG
Hi I have a 2000yr c220 CDI it has just developed a fault whereas it does not start when the engine is warm....leave it 20-30 mins and it will start. The engine turns over but does not fire... I have checked the 0 ring on the common rail thats fine, changed fuel filter (because I had one in the garage for the last 2 years).
Does this sound like the crank speed sensor I have read about on here?
Cheers
Andy
Alex Crow
Super Suffolk
yes, it does.
As Alexander above £47 from Bosch service center or £87 from MB
They measure 1k ohms when good and near open circuit when hot and faulty
slimandylincs
North Lincs
Where do I find the position sensor and how do I go about changing it?
Andy
star
Reading
Smart + others :)
before we all jump at cranks sensor (normally on v engines), it could be fuel pressure (injector, wrong fuel etc?) just a thought.
harpersimon
Southwest
2015 A200 AMG line
or £41 from ECP . doable yourself if you are patient and good with cars generally. Just done mine (on a V6)
slimandylincs
North Lincs
Hi, I have changed the sensor and it has not cured my problem. The car starts fine 1st then when you have reached normal running temperature, and stop you can start the car for 5 mins after stopping it, any longer and it will not start for 30 mins, then all of a suddern it will start again. During the period of not starting the engine turns but does not fire. you can keep trying it and it will not start, but after an amount of time has elapsed it starts as normal. Strange really. Any ideas......
I also have a new CPS for sale.......as its not required...
Thanks for the previous advice... the CPS is easy to swop when you have thin forearms like myself..
Cheers
Andy
MB TECH WARRINGTON
Cheers
Andy
It sounds fuel related, be it injector, pump, pressure sensor etc.
Needs someone good to look at it for you so you dont waste more money
This is only the 2nd time that this has happened out of hundreds,,It sounds the same as Petes car that we were talking bout today,,possibly the CPS,,in some cases even STAR will not pick this up
slimandylincs
North Lincs
Can anybody suggest somewhere sensible to take the car (I am in the North East Lincolnshire Area). I am not into main dealers, they tend to frighten me....Will be glad to get this sorted as its the other half's car and she's been giving me hell, that its not sorted yet....
Just to add the car drives fine when you get it started, today I used it to tow my trailer with 3/4 ton in it, pulls and accelerates like a train.....
At least my Subaru is not as tempermental...lol
Cheers
Andy
turbopete
Spennymoor
later on when mine started, it was showing the symptoms of a pressure regulating valve being faulty. i suppose the fuel will be thinner when its warm and as a result will flow through a faulty pressure relief valve more easily when hot (when it shouldnt be flowing through it at all) than when the fuel is cooler and thicker
star
Reading
Smart + others :)
Cheers
Andy
Unfortunately this also shows the cost of guessing, I would have thought if you had a diagnostic check done 1st, it would have saved you money and resolved the problem straightaway. Just a thought.
mercslk11
I have the same problem with a 2003 320cdi starts ok when cold, but then once you stop it will turn over but wont start, after switching the ignition on about 10 times (but not actually cranking it )each time until the glow light goes out it then starts.
Mbtech warrington how much would it cost to look at it
seancah1
New Registration
NEWRY
E320 cdi 2003
Hi I have the exact same problem
My car is an e320 cdi 2003 and it's doing exactly what you are describing. What was the cause of your problem in the end? I've checked the injectors and they're fine. Thanks.
Dogfish
South of England
CL203 C220 CDI SE Sports Coupe. 2002.
My W203 2002 was doing exactly the same.
Star in Reading did a "leak off" test and put it on the diagnostic star machine and found that an injector was returning too much fuel.
This also seemed to drain the opposite side of the tank of fuel which led to fuel starvation as well.
Before going to Star in Reading (for front struts to be done actually), a good indie, the dealers fleeced me for new gubbins for the fuel tank which did not sort the problem. Gutted and several hundred quid lighter.
