Hi Malcolm I assume that you mean last three digits of chassis no which is 202
Also car is first reg 04.05.2004 . Thanks Tom
It must be a WDB203 for that year Tom
Sounds to me like a fuel problem, either a quantity control valve on the fuel rail, or and injector issue, the codes need to be read and the actual values read to see whats causing it.
Yes Ellsy says fuel, and I think so to, it has to bee, if it was the CPS it would cut on heat,rather than RPM, see what I can find in the morning
It wouldnt supprise me if the to faults are linked, possibly high pressure pump as that can cause the tank issue, and may be causing the lack off fuel pressure and cutting out.
