jberks said:I think you are right. aside from the fact that it can't change down when it needs to and you'd need an extra switch on the clutch pedal to disengage it.
I have cruise on the jeep and that's a manual.
Sorry Malcolm, I have to disagree. On an auto, the brake disengages the cruise, on a manual both the brake and the clutch do it. Otherwise, if you depressed the clutch, the cruise would maintain the throttle and as no longer under load, the engine would overrev.television said:Cruise control is only ever and always disengaged by the brake pedal,it is nothing to do with cluctch or gearbox.
Malcolm
The cruise control can be shut off by any of the following methods:
1. Depressing the brake pedal.
2. Depressing the clutch pedal, if a clutch switch is fitted.
jberks said:Sorry Malcolm, I have to disagree. On an auto, the brake disengages the cruise, on a manual both the brake and the clutch do it. Otherwise, if you depressed the clutch, the cruise would maintain the throttle and as no longer under load, the engine would overrev.
Its not a big issue and you can get after market cruise control kits for manuals too.
You are right,sorry I was just going to make amends and of course the Tiptronic was used with manual cars up to about 93 I think.
Very sorry
Malcolm
fionanallan said:Ours is also a C220 CDI manual...with cruise control. Came as standard fitment in the car. Although to be perfectly honest, we've never actually used it! Suppose we'll get round to trying it one of these days!
However, it also says under standard fitment423 5-speed automatic transmission with Tipfunction and Speedtronic cruise control
SO I guess its standard no matter what now. However, I don't believe this was always the case so it may be that older ones were auto only. I remember my dads 94 C180 auto not having it whereas my 95 C220 Auto did.6-speed manual transmission with Speedtronic cruise control
television said:Try the cruise control 5PM on the M25 it will change the way you drive.
Malcolm
Don't understand, I thought it shut off when you stopped!Try the cruise control 5PM on the M25 it will change the way you drive.
That never worked for meWezzel said:When I don't use it I subconciously seem to speed up on the downhill and ease up going uphill.
