kevinchard
- Nov 30, 2008
My low mileage C220CDI (30K miles) is 6 years old, serviced privately on time (3 times) by a reliable mechanic using genuine parts gave no problems until yesterday. The car is parked in a garage and yesterday morning started ok but then I stalled it reversing. After that not able to start the car. The key fob works ok. The ignition switch recognise the key and all the dash lights come on including the preglow light but key on position 3 ignition switch is not firing.There is a clicking noise in the background coming from the on board computer I presume but not 100% sure. Any suggestions please on how to trouble shoot "step by step" in order to identify the fault and fix the problem without having to go to Merc garage?
Same symptom when tried to jump start, so the battery is not suspect.
It is a WDC203 model, came out of the factory in South Africa in Dec 2001,
personally imported to UK via Mecercede-Benz Hamburg, Germany.
Kevin
Kevin
