Hi all, I currently own a c250 cdi and it has a rattle on a cold start for around 3 seconds and then it stops. Been told by a garage it could be the timing chain tension needs sorting. Has anyone ever had this problem? If I keep using the car in the mean time like this what could happen?
The car now and again looses a bit of power at 70mph but not limp mode. When plugged into STAR is came up with ‘ there is an internal control fault in the monitoring function for the fuel injectors. There is an implausible signal’ has anyone ever heard of this and know what needs to be done to address the problem as the garage wasn’t too clued up.
Thank you all in advance
