Hi, new member here looking for any help I can get.
the blower has an intermittant fault where it will please itself when it works.
the fuse was ok so I went to the blower motor which was getting a live feed from the switch but not operating. I discovered that the blower would work if i gave it a manual spin to "kick start" it. I decided at this point that it was the motor so purchased a second hand one, £65, from Dronsfield Merc' of oldham.
fitted the replacement but still operated intermittant or with a "kick start".
decided then that it was the resistor pack ( voltage regulator? ). Dronsfield kindly exchanged blower for resistor, fitted there and then but no change swapped that one for another still no change.
the guy at dronsfield said it could be circuit board,£100, am reluctant to chang it untill have some more advice.
can anyone please,please help. does the controller give it a higher initial charge to "kick start" the fan?
had a trawl through the previous threads, frightened myself to death with all the diverse problems that occure.
cheers,
mick billy.
cheers,
mick billy.
