C250TD Misfire and surging.
momalloba
I have an intermittent misfire normally,but not always, when the engine is under light load.The car also produces an occasional,undemanded,momentary surge of acceleration.Two fault codes are stored,1470 boost pressure control and 1630 immobiliser.The former seems more feasible to me.Does anyone out there have knowledge of the various sensors that control the boost, and the chances of them failing ? Would the MB dealers computer nail the problem to a specific component ?
Many thanks.
Hello and welcome,, you could spend ages looking for the fault,,an indie will charge you 30ish to plug it in and get a fault code read out
M
momalloba
Thank you `television`for your response.Would the indie give a more specific indication than the `1470 boost pressure control `readout of my local garage via a `snap on`computer ?
No not really, the Snap On can read the engine faults. I do not know that much about diesels.
The charge air pipe is known to split or leak, and this affects the engine performance suddenly
www.W140.co.uk&www.r129.co
