C250TD performance
mcubed
Ordinarily I am reasonabily happy with my Benz, it goes like stink in first and second , although tails off a bit after that. This however becomes a real pain when pulling a mere 1000kg of "wheeled accomodation". I cannot get above 40 mph on anything more than the slightest inclines, even using the manual gear selection. Should I be looking to tune or chip, help please.
1998, C250TD, 70K miles, auto
Cooky
South Gloucestershire
Something doesn't sound quite right here. I use a C250TD auto estate and successfully tow a 1460Kg caravan. Even up the long steep motorway inclines across Normandy it will do 55mph in third gear (about 3300 rpm), and will go faster but gets a bit "rorty".
Are you sure the turbo is blowing properly, i.e. no loose air hoses or the like? Is the air filter clogged? Does it smoke (black) under acceleration? Is it manual or auto?
c250 turbo diesel
Possible cause
FIrst as said try air filter, then put a new diesel filter on, that is more likely to cause lack of power.
niva441
Warwick / Cambridge
I second the remark about having the filters replaced. Even at 215k my C250TD auto pulls strongly in all gears. Although I don't tow a mobile chicane.
M
mcubed
cheers!
Thanks for all who replied, will try changing filters.
M
mcubed
Job done
Filters were all okay so finally bit the bullet and took it into my local dealer. half an hour later I left in a virtual fliying machine. The hose to the vacuum pump had been resting on the turbo inlet and had worn a hole through therefore losing vacuum. Excellent service from the dealer who charges by the half hour and took nothing for the new hose.
Thanks again to all who responded.
sss100uk
C250 TD Loss of power
ive bought a C250 TD 1998 just a month ago and im having loss of power from the start. i wont pick as fast as it should and after going about 60+ it starts to slow down in picking up speed and the max ive hit is 85 mph which is crap for a 2.5 TD. ive had the turbo checked and works fine. you've mentioned you had a hose replaced could you tell me exactly which one it is so i could get it checked out.is it the one from the air filter to the turbo. its like a fat pipe??????
mstar
diesel filter? is that different to a normal filter??? how do i know which mine is fitted with? :confused:
Other name for fuel filter.
