C270 CDI Brakes
rpe2
Silchester
Morining,
Have had the 2002 car for about 4 months now, and just before we bought it it failed the MOT on brakes, and pads/ discs were replaced.
The brakes have no bite to them, the pedal feels a little spongey, I took the pads out yesterday to replace with a decent brand (Textar) only to find that I was replacing like with like.
I suppose my questions are:
1. ARe brakes on the W203 spongy/ vague as a characteristic of the car?
2. Are discs discs, or could a cheap disc cause this feel
3. Anyone else experienced this?
Richard
psmart
Textar are the OEM manufacturer for Mercedes brake pads.
My C is starting to feel spongy and vibrates heavily on the nearside front! There are a few problems with these cars, 1 is that the disks can be etched by the pads which cause vibration but also reduce braking efficiency. My C has had all disks replaced at around 10k due to this problem and now at 36K Im noticing the same problem again.
If you leave the car stood for a while such as at an airport, dont apply the parking brake, leave the car in gear (and chock it, try not to put loading on the transmission) as its a sure way to etch the rear disks. Also, if the car is left standing, the tyres take on flat spots and youll get a noisy ride with possible vibration.
Also, check the service history, when was the brake fluid replaced? The fluid absorbs water over time which reduces braking efficiency.
Hi Richard,,any spongy feeling would be air in the system
R
rpe2
Silchester
Thanks Malcolm,
I think that a throrough bleed of the system would do no harm.
Will have a go at the weekend.
Richard
