C270 cdi loss of power
RGAV1976
Was driving down the road when the car lost its power and black smoke started coming from the exaust. Took it to a garage, he plugged his laptop in. Could'nt find any faults and he said he turned down the turbo boost. Can you do this using a laptop? Since then ive had the EGR valve blanked off, that stopped the black smoke. All pipes checked out, no leaks and the intercooler was leaking air so i had that changed. If you squeeze the intercooler pipe you can feel the turbo boost. Tried it with the MAF disconnected, still no difference. Car drives really smooth but turbo's not kicking in.
rpe2
Silchester
Is the air filter clean?
Also, don't understand how you can feel the boost, as the turbo wastegate won't move when in park..
R
RGAV1976
The air filter is brand new. The mechanic said if you rev the engine and you squeeze the intercooler pipe you can feel the boost going through. Or is he having me on!
R
RGAV1976
Can you turn down the turbo boost using a laptop?
MB TECH WARRINGTON
check the black pipe going to the egr valve, on the front right hand side of engine, its about 3-4inches in diameter, these are very common for splitting on the 270cdi, causing the exact symptoms you are stating.
If you look at this pipe when someone is revving the engine you will hear it hissing if it is split
rpe2
Silchester
Thanks, thought it was only when in drive.
Consider myself corrected.
Alex Crow
Super Suffolk
we really need your fault codes to help. no, he can`t turn down the boost with a laptop :eek: . i use star and among it`s myriad windows of functionality i cannot raise/lower boost levels, lower displayed mileage, or anything else mercedes does not want me meddling with! :roll:
the more common causes of your symptoms are split hose or intercooler, faulty air mass sensor, sticking egr valve (it concerns me that this has been blanked off) or blocked catalytic convertor/s.
if you can get the fault codes this would help, but ideally i would need to see live data and do egr and air mass tests etc.
Alex Crow
Super Suffolk
should also add, we see some turbo faults with the variable vane turbos with the y100 servo actuators on cdi3 engines.
Welcome to the forum alexander nice to have you on board
R
RGAV1976
A laptop's been plugged in and there were no faults. There was a hissing noise when you accelerated, but now the intercooler's been changed the hissing noise has gone. Only noise left is a loud whining sound when i'm driving. When you put your foot when stationary the turbo doesn't kick in like it used to. It kicks in once you are moving. The mechanic said he blanked the EGR valve off to stop the smoking. Its done that but doesn't drive nothing like it used to. It's been remapped, so it was pretty fast before this happened.
