James100474
- Dec 19, 2006
Hi all, just purchased a C270 CDI which knocks when on a slighty rough surface. Have replced worn roll bar bushes and links. All joints seem to be ok, any ideas. Thanks.
Hello Guys, just curious, how do you remove the ball joint pictured. It looks like there is only 1/2" clearance to lift it before it will foul the strut
I can see a few options, but I'd rather know the easy was first time
Cheers All
You have to unbolt the strut and move it out of the way also the drop link.
Thank you for the reply, but forgive me for silly questions here (never unbolted a strut before ).
Would I remove the two bots from strut to hub, and the nut&bolt from barcket on strut (just above the brake disc), to the top of hub.
If I unbolt these, would I not need to compress the coil spring?
