Jasonmerc
Hi all new member here... I was after some advice I have issues that affect my c270 in the freezing weather only. When it's warm outside its starts like a dream. But as soon as the weather freezes it's a nightmare. I have done a leak off test on the injectors and they are all leaking off in the parameters, I have have changed I rings on the pressure regulator, still no difference. I have put in a new battery. I have put in all new fuel lines approx 4 years ago. Brand new O rings with the fuel lines. There are no air bubbles in the fuel lines. I have got a refurbished high pressure fuel pump a few years ago because my old one failed. To start it in the freezing weather I have to spray a bit of Easy start and crank it for about a minute ( must be killing my new battery). Please help?? Running out of ideas. Thanks Jason
