silversixx
- Dec 16, 2008
Hello all,
I recently acquired a '96 C36 AMG with 65,000 documented miles. It's my first Mercedes-Benz and so far I'm very happy with it on the whole.
I've replaced the oil, filters, plugs, coolant, serpentine belt and pulley and as far as I can tell the car performs as it should with plenty of power. After 2000 miles it has used no oil or coolant and is returning in the region of 25mpg.
The thing is... as soon as the motor is no longer cold (i.e after a few minutes of running and long before it is properly warm) and at a standstill, it sounds like a really smooth modern diesel motor at idle with that distinctive 'klatta-klatta' sound. As you pull away, at about 1900 rpm the noise vanishes as if a switch has been flicked.
My initial guess was that this could possibly be the chain tensioner, but the tensioner is located quite far down at the front of the motor whereas the noise seems loudest at the fuel rail/inlet cam area. The local MB dealer could only suggest 'dismantling the motor to see if we can find anything'. I politely declined!
Looking online, across the world people with C36's report the same thing and have a whole host of explanations: the special Mahle (as opposed to Kolbenschmidt in all other MB sixes at the time) pistons, the tensioner, the chain, excessive cam wear etc etc... Everyone seems happy to live with it and some report that the noise has been there for many thousands of happy and reliable miles. The only case I found where the sound was made to go away was when someone connected some sort of module to their car which allowed them to swith the inlet-cam variator on at idle. Some other guy reckoned that if you get out there and thrash the living daylights out of the car down the motorway for 20 mins then it would go away, but that's not really my way of resolving the problem!
Does anyone here have an opinion as to what could be causing the noise? It's not that bad, and all signs are that it's not causing any harm at all, it's just...not what I expected from a Mercedes-Benz and I'd love to get to the bottom of it.
Of slightly less irritating nature is a 'vacuum cleaner' sound from under the bonnet which accompanies the engines RPM and gets louder as the revs rise. The only adverse effect of this is that it gets so loud at mid-to-high revs, I can't hear the lovely sound that the motor is probably producing!
If anyone can help me with either issue then you'd be helping me to transform a surprisingly-enjoyable first-time Mercedes-Benz experience into a great one, and I'd be in your debt.
