calling all experts, input required
MB TECH WARRINGTON
how do you guys go about the fault with secondary air injection fault, air flow too low?
on 203 200k
Cole@MBS
www.mbssouthampton.co.uk
Its the relay that burns out and keeps the pump running???
Cole@MBS
Just to add, its the same relay on the 220 model which controls the air-matic pump, that then burns out!! loads of cash due to a relay!!
Cole@MBS
Thank you sir, does this mean i buying lunch next week, or is it LULUs turn!!!
Cole@MBS
Ah, bit of home work needed here! thought you were talking about the late AMG lumps!!!
MB TECH WARRINGTON
MB TECH WARRINGTON
nope sorry pal, was a momentary lapse, i thought you were psychic;)
ie a 203 200k, engine light on the dash, fault code; secondary air injection malfunction, air flow too low.
cant think of code at hand,
the valve is located at back of head, operated by vacuum,
had a few problems with one lately, all sorted now i hope,
was just wondering if you guys have experienced it,
Cole@MBS
Check the small pipe under the engine ECU and the gubbings, seen them spilt and give the same fault code!!
different system on the 111 engine, works via vacuum which opens valve and gives increased air flow into throttle housing,
I will read it up and see what I can make of it
MB TECH WARRINGTON
MB TECH WARRINGTON
  • #17
first thing we checked, the filter below the valve was seriously blocked, changed this, all vacuum pipes are ok, erased fault,
after 1 week, car back with same fault.
had it in this week and hopefully now sorted, was just wondering if you guys have had this one and what you did to remedy it?
Cole@MBS
Still put money on that small valc pipe!!!
Cole@MBS
Caught me out twice before i found it, its not a vac pipe, its out of sight! i will try looking up on EPC tomorrow, cant see it on wis, let you know tomorrow mbtec!!
www.ckinsurance.co.uk
