Cam belt change?
Dangedan9
A class 2014 a180
Hi I have a A Class 2014 a 180 diesel model. Does it have a cam belt? And st what mileage/ years shoukdbit be changed? Thanks
mersum1es
Finland
2014 A 180 CDI can be fitted either OM651 (1,8L) or OM607 (1,5L) diesel. OM607 is renault based lump and has BELT drive
gianton
Thessaloniki, Greece
S204 C250 CDI 4Matic Avantgarde - 2013
Post your VIN and I'll check it for you.
Sent from my Pixel 2 XL using Tapatalk
Check the engine number on the V5. The first three numbers will show which engine you have.
651xxx... or 607xxx...
Those numbers define your engine model and submodel (the xxx is the submodel)
