PJayUK
- Oct 7, 2008
Just reading a few posts about idle speed issues which has raised a few questions that I was wondering if someone can help with.
Basically my 2000 S320 idles when warm at around 850RPM. Last week the car was at a local indi and hooked up to STAR diags. All clear no issues or faults identified. The technician said not to worry about it, but it still seems a little high. He reset all the ECU adaptive values which actually seemed to make the car feel slightly smoother running but had no effect on the idle.
So got me thinking....
The car had a new pair of airfilters a couple of months ago. Unfortunately they were el'cheapo aftermarket ones and not MB ones. I was wondering whether using these might affect the airflow and cause some impact to the idle speed.
Would a good clean of the throttle body and butterfly valve help things out? I seem to recall that the valve flap is rubber or plastic not sure but looks flimsy. Is there a standard procedure for cleaning this, or perhap a WIS bulletin that I could refer to?
Now this will sound daft, but I think this problem has only started since I switch to using Shell V-Power in the car. Could this have caused any impact, on idle speed?
As always any advice is gratefully received!
